W piątek otrzymałem przesyłkę z HK od YONGNUO, wewnątrz była ciekawa ulotka o zapowiedziach:
Dear users:
Many thanks for purchasing YONGNUO YN series of speedlights!
We are very glad to recommend our speedlight products to you.
Our new productS(RELEASED or coming SOON, visitwww.hkyongnuo.com for more news)
YONGNUO 2.4G Wirełess flash system
YN460- TX 2.4G wireless TTL commander
YN460-RX 2.4G wireless TTL speedlight
• 2.4G Wireless flash system supported
2.4G wireless TTL flash has been achieved to help you seize every precious moment.
• Multiple wireless flash control supported
A TTL group and two M groups for the wireless flash system; every group can be adjusted
output level independently.
• Remote Power Control on YN460-TX
You won't move back and forth between camera and speedlites any more, the efficiency will
increase by more than 60%.
• Rear-curtain supported as well as FEC, FEB
• Two PC ports for synchronous 1/0
There are two PC ports, one in which is used for signal input, and the other is for the synchronous
signal output. In particular, the PC port for the output also supports the rear-curtain sync.
• Vast-distance wireless flash control
It achieves the remote wireless flash control with the maximum distance over 200 meters.
• There are seven user-configurable wireless channels that can effectively prevent the wireless
interference, and maximize the reliable use in the complex environment.
• Support for up to 16 YN460-RX speed lights
A YN460-TX can make 16 YN460-RX speedlites flash at the same time, which can provide the
better creativity, achieving the speedlights applied in large-scale night illumination.
Wirełess speedlite transmitter ST-E2
• Wireless TTL flash controi
• Ultra-AF for over 25 meters
• FEC supported
• FEB supported
• Modeling on depth of field preview
• Rotatable
• 4 wireless channels
• 2 groups of Flash ratio control
• High-speed sync compatible
• Supports 580 EX II and 430EX II
• Supports YONGNUO's EX series flash
(This series will be released later in 20 l O)
Zapowiada się dość ciekawie ta lampka.
Dear users:
• FEC supported
• FEB supported
• Rotatable
Komentarz
